Konfiguracni manazer pro kabelovy modem
  • po 3 týdnech...
V nastaveni modemu, zapni "Enable DHCP Server".
Ale nevim jestli to bude mit nejaky efekt, protoze se tam pise ze ten DHCP server je tam na to, kdyz je modem odpojen od internetu.
"When the Cable Modem is disconnected from the Internet, users on the LAN can be dynamically assigned IP Addresses by the Cable Modem DHCP Server".
https://www.techforum.cz/topic/22-konfiguracni-manazer-pro-kabelovy-modem/page/2/#findComment-1903
Litomerice
Modem Motorola SB5100E-CN
Downstream Value
Frequency 351000000 Hz Locked
Signal to Noise Ratio 37 dB
Power Level 3 dBmV
Upstream Value
Channel ID 4
Frequency 22800000 Hz Ranged
Power Level 52 dBmV
https://www.techforum.cz/topic/22-konfiguracni-manazer-pro-kabelovy-modem/page/2/#findComment-4272
Software Version: SB5100E-2.3.2.2-SCM02-NOSH
Hardware Version: 3
MIB Version: II
GUI Version: 1.0
VxWorks Version: 5.4
Downstream:
Frequency 378000000 Hz Locked
Power Level -2 dBmV
Upstream:
Channel ID 1
Frequency 23248000 Hz Ranged
Power Level 41 dBmV
  • Základní, Family, Sport
https://www.techforum.cz/topic/22-konfiguracni-manazer-pro-kabelovy-modem/page/2/#findComment-4273
Návštěvník Kema
Teplice - Bohosudov
Hardware Version: 3
MIB Version: II
GUI Version: 1.0
Downstream Value
Frequency 363000000 Hz Locked
Signal to Noise Ratio 34 dB
Power Level -9 dBmV
Upstream Value
Channel ID 3
Power Level 45 dBmV
https://www.techforum.cz/topic/22-konfiguracni-manazer-pro-kabelovy-modem/page/2/#findComment-4352
