Odesláno 27. prosince 2013 11 let Hello everybody, sorry for writing in English but it will be worse if I will translate in cz with google. I want to ask about the signal strenght of UPC digital signal. I installed the package almost 1 month ago, the option with CAM on the TV. I remember when it finally worked (the technician came and removed the filter from UPC box in the basement) I had something like 80% strength and 100% quality on all frequencies. Few days ago I just checked the signal level out of curiosity.. and I noticed that the highest is 66% and the lowest 50%. The quality is still 100%. What happened? For sure nothing changed in my home, the cable is in the same position as before. These 50% signal strenght is normal? What is the acceptable level? All the channels play perfect.. only once I noticed some few blocks on the screen on one evening..
Odesláno 27. prosince 2013 11 let The signal strength is very relative value, which it is not possible to compare with data on other receivers. The values of the signal strength may vary, even to different sets of the same manufacturer. Important is the only signal quality, it should be at least 90% of the measured value, better and higher. If there has been a significant decrease in signal strength a few days before, very likely is somewhere on the cable connection – small movement of the cable, to be such an imperfect connection to take effect. Check the perfect connection of the connectors on both ends of the cable. Until you're 100% sure that the problem is not in your wiring, call (or send an e-mail) at the Customer Service Centre of the UPC. You can also look into the interface of your modem, what are the values of the signal strength and the signal to noise ratio (SNR). The signal strength should be between -10 dBmV and +10 dBmV and SNR of at least 35-40 dB for download on all channels.
Odesláno 27. prosince 2013 11 let Ok, thanks for complex answer. I am sure the connection is good, my cable is not the best on the market, actually it was pretty cheap, 100kc for 10m with already built connectors bought from Globus. I don't even think the central wire is solid copper, looks too flexible. I have 100% quality on all frequencies, so it should be OK. I never experienced any problem with the signal, the TV has an option to store every "falling" of the signal, and nothing is recorded on that log. I checked the SNR on the modem and is 38 - 39 dB on all frequencies on download, so it should be fine. Thank you Retiree.
Odesláno 27. prosince 2013 11 let Your cable is really not the best on the market. The central wire is stranded copper, because it is flexible. The entire cable with connectors called "Účastnická šňůra" (subscriber line/cable) and usually has not good connections with the connectors… I recommend to buy the necessary length of shielded cable (75 Ohm) and F-type connectors on the diameter corresponding to the diameter of the cable and, where appropriate, reduction of F on the IEC connector. I attach one of the many video tutorials on the installation of the F connector. Přikládám jeden z mnoha obrázkových návodů na montáž F konktoru
Odesláno 28. prosince 2013 11 let I checked the SNR on the modem and is 38 - 39 dB on all frequencies on download, so it should be fine. What is the level of the signal indicates the modem on downstream ? Kabel 150 Mb/s - Komfort Compal VF, VTV box, CA modul Brno
