Nemate nekdo problem s vysokymi pingy bez zateze?
U me se to projevuje tak, ze kdyz neni traffic, tak mam pingy treba az 1000ms, kdyz pustim stahovani, tak jsou v pohode 10-15ms. Je to otravne hlavne pri praci pres konzoli (telnet), kde skoro nic netece, tak to pak reaguje desne neprirozene.
Takhle to presne vypda: (nejdrive vysoke pingy, pak pustim stahovani, tak jsou ok, a pak jsou zas vysoke)
64 bytes from 77.75.72.3: seq=59 ttl=248 time=1011.169 ms
64 bytes from 77.75.72.3: seq=60 ttl=248 time=24.193 ms
64 bytes from 77.75.72.3: seq=61 ttl=248 time=63.243 ms
64 bytes from 77.75.72.3: seq=62 ttl=248 time=38.984 ms
64 bytes from 77.75.72.3: seq=63 ttl=248 time=1012.801 ms
64 bytes from 77.75.72.3: seq=64 ttl=248 time=12.639 ms
64 bytes from 77.75.72.3: seq=65 ttl=248 time=638.557 ms
64 bytes from 77.75.72.3: seq=66 ttl=248 time=69.782 ms
64 bytes from 77.75.72.3: seq=67 ttl=248 time=1012.455 ms
64 bytes from 77.75.72.3: seq=68 ttl=248 time=25.090 ms
64 bytes from 77.75.72.3: seq=69 ttl=248 time=1011.761 ms
64 bytes from 77.75.72.3: seq=70 ttl=248 time=23.527 ms
64 bytes from 77.75.72.3: seq=71 ttl=248 time=1010.573 ms
64 bytes from 77.75.72.3: seq=72 ttl=248 time=23.047 ms
64 bytes from 77.75.72.3: seq=73 ttl=248 time=783.161 ms
64 bytes from 77.75.72.3: seq=74 ttl=248 time=439.649 ms
64 bytes from 77.75.72.3: seq=75 ttl=248 time=23.953 ms
64 bytes from 77.75.72.3: seq=76 ttl=248 time=12.577 ms
64 bytes from 77.75.72.3: seq=77 ttl=248 time=11.121 ms
64 bytes from 77.75.72.3: seq=78 ttl=248 time=11.992 ms
64 bytes from 77.75.72.3: seq=79 ttl=248 time=12.680 ms
64 bytes from 77.75.72.3: seq=80 ttl=248 time=13.358 ms
64 bytes from 77.75.72.3: seq=81 ttl=248 time=13.802 ms
64 bytes from 77.75.72.3: seq=82 ttl=248 time=14.041 ms
64 bytes from 77.75.72.3: seq=83 ttl=248 time=13.744 ms
64 bytes from 77.75.72.3: seq=84 ttl=248 time=14.445 ms
64 bytes from 77.75.72.3: seq=85 ttl=248 time=13.318 ms
64 bytes from 77.75.72.3: seq=86 ttl=248 time=11.173 ms
64 bytes from 77.75.72.3: seq=87 ttl=248 time=12.353 ms
64 bytes from 77.75.72.3: seq=88 ttl=248 time=15.640 ms
64 bytes from 77.75.72.3: seq=89 ttl=248 time=11.987 ms
64 bytes from 77.75.72.3: seq=90 ttl=248 time=30.228 ms
64 bytes from 77.75.72.3: seq=91 ttl=248 time=11.764 ms
64 bytes from 77.75.72.3: seq=92 ttl=248 time=13.476 ms
64 bytes from 77.75.72.3: seq=93 ttl=248 time=14.450 ms
64 bytes from 77.75.72.3: seq=94 ttl=248 time=14.441 ms
64 bytes from 77.75.72.3: seq=95 ttl=248 time=13.096 ms
64 bytes from 77.75.72.3: seq=96 ttl=248 time=12.724 ms
64 bytes from 77.75.72.3: seq=97 ttl=248 time=471.722 ms
64 bytes from 77.75.72.3: seq=98 ttl=248 time=878.574 ms
64 bytes from 77.75.72.3: seq=99 ttl=248 time=127.694 ms
64 bytes from 77.75.72.3: seq=100 ttl=248 time=46.047 ms
64 bytes from 77.75.72.3: seq=101 ttl=248 time=988.502 ms
64 bytes from 77.75.72.3: seq=102 ttl=248 time=874.734 ms
64 bytes from 77.75.72.3: seq=103 ttl=248 time=1010.350 ms
64 bytes from 77.75.72.3: seq=104 ttl=248 time=26.279 ms
64 bytes from 77.75.72.3: seq=105 ttl=248 time=42.793 ms
Poradite, cim by to mohlo byt? Da se to vubec nahlasit jako porucha? A vsiml jsem si toho az dneska, takze to mozna nedela pokazde (a nebo proto, ze jsem zatim vzdycky neco stahoval :D )
Já to vidím, že využíváte maximální rychlost svého internetu, to se mi též stává, ale ping nemam přes 1000ms to rozhodně ne.
Nemáte náhodou zapnutý upload ?
// EDIT: Stáhni WINMTR a dej tam seznam.cz a po nějakých 100 pokusech to sem hoď .-)
  • Kabel 300 Mb/s
zkus schválně ping na router, tipl bych to na nějakou spořící funkci síťovky :)
Dekuji za odpovedi. To jsem uz zkusil, ale po lokalni siti vsecko funguje perfektne, i pres wifi. Ledaze by ten router uspaval sitovku jen do wanu, ale o tom dost pochybuju, to by to delal nejspis i na te do lanu, kde se taky zadny data neprenasi. Nema cisco 3208 nejakou spaci funkci? :)
No prave uplne obracene, ze kdyz ho vyuzivam naplno, tak mam pingy jako vino :-)
Zkusim, az se tam dostanu s notebookem, potiz mam s tim "win", protoze to, na cem vzdalene delam a co je pripojene prave pres UPC, je linuxovy stroj jen s prikazovou radkou...
ja bych videl to asi takhle pokud budes pouzivat sumt router s upravenym fimwarem tak to bude tvym problemum odpovidat
Bud v klidu, flamere, ten router zvladne hrave unatovat jednou tolik i pres wifi, takze mam slusnou rezervu ;) Uz to zas jede 40, asi meli nejakej linej den. Asi podle toho, jakou zrovna dostanu IP, nebo byla v Londyne proste mlha :jocolor:
az po mem, prispevku jako vzdy jsi nasel chybu a tentokrat si to zase svedl na modem
Upraveno uživatelem frelo
Uklidni se, lepidlo, a netapatuj nesmyslama, kdyz o tom zcela zjevne vubec nic nevis :roll: A laskave cituj prispevky k tematum, ke kterym patri a nevytrhavej z kontextu. Ze UPC proste nekdy nedava celou rychlost zrovna tady neresim. Se divim, ze te to bavi psat pod kazdy muj prispevek... Konkretne tech routeru wr841n mam v provozu X na ruznych pripojkach od optiky az po tuhle u UPC a je zajmavy, ze by to delalo zrovna jen na UPC, kdyz jinde tyto problemy nejsou. Jinak spravuju ruznych modelu tp-link, o kterych ty tvrdis sunt, nekolik desitek a vsechny jedou od pocatku instalace uplne bez problemu, vzdalena administrace i na neverejnych IP, umi vsecko na co si clovek vzpomene, proste parada, jenze to tobe nema cenu vysvetlovat, ty si budes porad mlit svou, protozes tp-link zrejme nikdy ani nevidel, a nebo sis nebyl schopnej nahrat aktualni nebo alternativni firmware. Ostatne i ten oficialni od tp linku docela funguje, neni problem uptime pres rok, jen nema tolik funkci.
Nechme Lepidlovy mindraky stranou, prosim o relevantni pripominky k tematu. Diky. 8)
Já třeba na Ubuntu používám mtr seznam.cz přes terminál nebo případně můžeš použít traceroute
  • Kabel 300 Mb/s
Dekuji. Tak uz jsem dojel k pripojce, pripojil notebooka naprimo a porad stejny problem. Po restartu cisca stale to same. Tak jsem zkusil vyresetit cisco tlacitkem vzadu a pingy jsou zas kolem 12ms, router jsem ani nerestartoval, IP zustala stejna, router za to nemoh, ifdown wan a ifup wan jsem zkousel i nadalku a to bylo na nic.
V ciscu bych ten problem teda nehledal :roll: Kazdopadne dekuji za rady.
