Samsung Blueray I've mentioned has the functionality as settop box with CI slot and DVB-C (cable) tuner as well wit HDD record, timeshift, anynet+ etc.
Or depending on TV you have, you can use CA modul directly without any settobox, if your TV has Common Interface slot.
Thanks so far.
My TV doesn't have tuning or a CI slot.
I have a BD player, no CI slot.
I just want a small black set top box with HD, CI and dvb-c for 2000kc to 3000 max.
Thanks so much!
