Odesláno 2. května 2017 7 let Podla poslednej specifikacie 802.11n z 2012: APs/routers must default to 20 MHz bandwidth mode in the 2.4 GHz band. They may switch to 40 MHz bandwidth mode only after satisfying multiple criteria, including no "fat channel" intolerant bit set and no interfering APs. In addition, to meet spec, APs/routers are not allowed to have a "40 MHz only" mode in the 2.4 GHz band. Dakujem za informaciu, o tomto som ani moc netusil. Takze to znamena, ze ak by som si kupil napriklad tento nenarocny wifi router od asusu https://goo.gl/3bPLu0 , tak by som i tak nemal moznost si nastavit v nom sirku pasma iba pre "40mhz?" pre 2,4ghz siet?
